Hi TI,
Whether UCC256304 can be used for battery charger application and confirm upto what power level I can use the same IC.
Yashwitha T L
Hi TI,
Yashwitha T L
Hi Nandakumar Lakkoju,
Is your question referring to maximum output voltage? If so, the maximum output voltage is dependent on the power stage parameters such as the turns ratio of the transformer and maximum attainable gain in the LLC tank.
Ben Lough
