Customer used TPS65162 LCD bias , and they won’t use the voltage shaping function , so they will not use VFLK pin
And there is not any description in datasheet about how to deal with the VFLK when not used.
Could you pls help on this
How to deal with the VFLK pin when not use?
Now, I asked Skyworth to use a 1K resistor pull down to the ground as it is an input pin.
Is the external circuit changed if VFLK is not used?
