  • Resolved
TPS65150: Some question about TPS65150
Part Number: TPS65150
I have some question about below.
1. TPS65150 have EMI class B know issue?
2. What is the VGL minimum voltage? If I want set VGL to -7V, set R1=  865k, R2= 150k, right?
3. VGH and CPI voltage level is the same?
4. If Vs=13.5V, I want set Vcom voltage to 3.8V, set R7= 1276k, R8= 500k, right?
  • Hello JeffYC,
    1. Not that I know off, but as with any DCDC converter, layout is important to reduce EMI.
    2. Please check out this application note:
    3. Yes, there is just a transistor between these.
    4. The ratio of your resistors need to follow the resistor divider formula: (R7+R8)/R8 = 13.5V/3.8V.
    Brigitte
    Brigitte
