USB2ANY tools is used to download the code for TPS65156. But in the process of debugging, USB2ANY is very easy to be damaged, almost 10 until now, it is found that SDA is short to GND.
Usually it is easy to be damaged in some certain concentrated time. They are already very cautious when downloading the code to make sure the pin will not connect to high voltage node.
Any suggestion for this?
