The datasheet shows the VGH1/2 is 12V~38V. What will happen when it is powered by 7V? UVLO?
Or it will depend on the voltage |VGH1/2|+|VGL|?
Thanks.
Thanks.
Hi Liaqat,
"I reviewed the datasheet and there is no UVLO. The part will likely operate at VGL1/2 of lower than 12V but the performance (such propagation delay, rise/fall times and other datasheet parameters) are not specified below 12V."
You refer to VGH1/2, correct? Just a typo? What is the voltage value do you think which will make even the chip not work?
Thanks.
Robin
