I just ran into a problem with LM3414, where we're getting some dim-pin related failures (no fires, but apparent failure of the pullup current source or input circuitry possibly due to over voltage). I need to design a protection circuit for this pin.
The data sheet is lacking some needed information about the dim pin. can you please provide:
1. equivalent input circuit
2. I(ih) and I(il) (current at Vih and Vil), and leakage current
I'm trying to figure out how to protect this pin, as I want to drive it from quite a long way away.
Looking at the block diagram there's a 30uA pullup current source on there - can this be easily damaged via overvoltage (or negative)? Would current limiting (resistor) solve this?
Is it reasonable to use protection diodes to GND and VCC (the VREG output) to protect this pin, or should VCC not be used for this (in which case, maybe a zener or Transil diode)?
Thanks!
