Is there a recommended frequency range when using UDIM for PWM dimming of TPS92641? In the data sheet I can only find 200 Hz (mentioned in figure 12 on page 8):
http://www.ti.com/lit/ds/symlink/tps92641.pdf
Same thing with the User's Guide for the TPS92641EVM (table 1, page 2):
http://www.ti.com/lit/ug/slvu823/slvu823.pdf
I would not mind using a slightly higher PWM frequency than that. Especially since I got a tradeoff between PWM frequency and PWM resolution due to HW limitations in the control MCU.
Göran Nordahl
