We are using the TLC5955 to drive a display with 96 channels. The GS values are no problem, and the display seems to be basically working. We have control of every channel.
However, we are having a lot of trouble with the Control Registers. They do not seem to be loading with the correct information. Maybe it is due to the use of so many 7 bit registers and the complexity of getting the data to break on the 8 bit boundaries. I don't know.
Anyway, is there any example c code written for this driver IC? It doesn't matter what microcontroller the code is for. We just need something to check our work against.
David
