I'm interesting to use multiple TPS92512(HV) together. We will probably pulse LEDs at 2A for a short period. I read in the datasheet that it's a good idea to sync together the drivers in multiple LEDs strings application (to avoid beat freq and EMI problem).
Is-it a good idea to phase shift the PWM clocks between LEDs drivers in that case?
I think it could decrease the stress over my input capacitors. If yes, do you have a low cost solution to do it (we will use 6x LEDs drivers)?
Denis
