When you are designing a PWM LED driver it is best to have PWM frequencies above the hearing frequency range around 20kHz. This is due to the piezo acoustic properties of ceramic capacitors. They act as loudspeakers.
Has anyone experience with 20kHz dimming for the LM3401 controller?
The datasheet states a method of an external FET switch across the LED string.
Best regards
Lasse Lund Hansen
