Hi, i would like to use TLC5958 for a RGB LED secreen I'm designing. But the datasheet has poor information. and http://www.ti.com/lit/ug/tidu370/tidu370.pdf don't help much. Where do I found refresh rate calculus for tidu370 paper? it say 3.5Khz refresh rate with 33MHz GCLK, but how to obtain this number?
It talk about 2 edge function o GCLK, but there is nothing on datasheet.
Datasheet talk about FC1 and FC2 register, but there is no bit by bit information abou this register neither how to acces them. what about command decoder, vsync signal?
You used to have the better datasheet compared with any other IC manufacturer, but this time I don't know why the info is so poor. Is tehere any other source of information?
Thank!
