hello all,
i am using Lm3409 EVM for one of my project.
The Evaluation board is doing perfect current control and changing the LED current from 0 to almost 1 Amp.
How ever when I change the load from LED to tungsten lamp, the LM3409 stops functioning.
I do not expect the bulb to glow at this low level current how ever I expect 1.0 Amp current to flow through the bulb.
Cold resistance of filament is around 0.75 Ohm which goes up as the filament gets heated.
Pl. suggest the remedy.
