Hi team,
I am looking to implementing TSP92630-Q1 to drive 3-LED strings with 3 LEDs at each string at 300mA/string using the parallel TPS92630-Q1 topology mentioned in the datasheet. I have been planning on enabling the Thermal Foldback functionality using a resistor at the Temp pin. I went through the documentation but I couldn't figure out what resistor I should pick for my design. Could you please help me figure out what resistor value I should pick and factors that determine the resistance at TEMP pin?
Thank you very much in advance!
Rifat Sheikh
