Hallo all,
My customer has several questions regarding our TLC59116.
What is the minimum power supply to achieve 120mA? What happened if the power supply voltage is too small to achieve the resistor programmed current?
Did the part generate an error message?
Customer wants to use the open circuit detection function to measure and detect open switches. What reaction speed is achievable with our part, if the customer uses a 400kHz I2C data stream?
Best regards
Olaf
