This question is regarding the uncompensated dc gain of buck-boost converter given in the datasheet of LM3424. I have attached a pdf which contains a block diagram of the peak current control using the LM3424 (may be generic). The uncompensated open loop gain contains all the parameters given in the datasheet except 500V. I do not get where the 500V comes from. I would like to know 1. Whether the attached control structure is correct and 2. Where does the 500V come from? Any Help would be appreciated.
Anand V R
