On the LP5521, a couple of the pins specify "output leakage current". When does this current come into effect? Please let me know if you need any additional information.
Thank you,
Julien
Thank you,
Julien
Hi Julien,
All those pins are open drain pins, I believe those numbers are the current when the lower FET is at the OFF state. If the pull up resister is connected, these are the max current that still leaks through the pin when the output is high, i.e. being pull up by the resistor.
H L
