Hi Team,
Does PWM duty decrease / increase in a linear manner in the range of following red part?
I believe it but would like to confirm just in case.
Yaita / Japan disty
Yes, your understanding is correct. PWM duty is linear, and actual duty ratio will be brightness(%)*1/(% of switch point of hybrid dimming). For example, if 25% is switch point, PWM duty ratio at 25% or lower brightness setting will be 4x of brightness setting due to reduced current by hybrid dimming.
Hope this helps,
