Other Parts Discussed in Thread: TXS0102
We are a startup creating a product which will feature 3 lp55231 led drivers.
We intend to power those lp55231 with the Li-ion battery, so Vdd will be somewhere between 3.1 and 4.2 V. Our plan is to use the typical application described in Section 8.2.1 of the spec.
We are unclear about the digital IO level in such configuration though. The spec is unclear, it refers to some VEN level, but the spec does not explain what this VEN voltage is. (See section 6.9 of the spec).
So how should we connect the I2C bus and GPIOs to our host ? Our host digital IO interface is 3.3V. Should we use a level shifter such as LSF010x, powered by Battery on one end and 3.3V on the other end ?
(our host cannot support voltage levels greater than 3.5V)
Please advise,
Thanks.
