Hi TI,
I am implementing DRL using the LM3423-Q1.
I want to implement the auto recovery function. Is it possible to implement the TIMR pin by touching 0 ohm to ground?
Or is there another way?
Thank you.
Hi TI,
Thank you.
Hello BJ,
The TIMR pin is reset internally by a pulldown to ground. So yes, if you want to reset the TIMR function manually you can pull the TIMR pin low externally.
Clint
