Hello guys,
One of our customers is going to evaluate TLC5927. The customer has some questions as the follows.
Could you please tell me your answer for the customer?
Q1. When LED anode voltage is powered up rapidly after TLC5927 OUTn is turned on, can TLC5927 control OUTn current correctly?
Also then is OUTn current not exceeded 1.5 times or 2times of a constant current determined by Rext?
Q2. Similar question to Q1.
When LED anode voltage is powered up rapidly same timing as TLC5927 OUTn is turned on, can TLC5927 control OUTn current correctly?
Q3. If Q1 or Q2 answer is the OUTn current exceeds 1.5 or 2 times of a constant current determined by Rext, what is the maximum current?
Your answers would be appreciated.
Kazuya Nakai.
