Other Parts Discussed in Thread: TPS92641, LM3409
Good morning,
we are designing a new RGBW LED driver for TV studio; we need very high dimming range, so we plan to use parallel dimming.
We have been using LM3409HV for years in EN dimming with very good results, so we decided to use the same for this project.
We need 5A output with 48Vin and 36Vout on LED string.
The board can be set for EN dimming or parallel dimming; in EN dimming power at no light is almost zero, but with parallel dimming it raises to about 3.5Watt.
Power on parallel FET is about 0.5Watt, the remaining is on Schottky, Pmos and inductor.
There is some suggestion to lower dissipation at no light output? Some app note?
Thank You for the attention
Franco
