Hi Team,
Is it possible to implement one-out-all-out functionality with the TPS92515-Q1?
Thank you,
Jared
Hi Team,
Thank you,
Jared
Hello Jared,
Could you explain "one-out-all-out" functionality a bit more? I'm not exactly sure what that is, but I'd be happy to try and help if you can let me know.
Clint
Hello Jared,
Ok, that's kind of what I figured. All of our LED drivers are constant current sources and will generally just keep running if one LED in a string shorts. The only real way to implement that would be to monitor the output voltage and if it suddenly drops below a certain threshold due to an LED short you pull down the PWM pin to turn the LED string off. I've asked others on the team that may have seen this type of requirement and they came to the same conclusion. I hope that helps.
Clint
