Hi Team,
When a fault occurs, either on fault or fault_s, I want the entire device to shut down. In order to implement this, can I tie both fault pins to the EN pin?
I am trying to implement a one-out-all-out scheme with the device. If connecting the fault outputs to the EN pin is not possible, is there another recommendation to implement one-out-all-out functionality?
Thank you,
Jared
