Hello guys,
One of my customers is going to evaluate TPS92661-Q after their own PCB making. TPS92661-Q1 has 2 terminals named VIN. According to Figure 26 in the device datasheet(SLUSBU2A), the resistance between each VIN is very low.
The customer wants to use the device with one terminal of VIN connection to power supply due to pattern routing limitation. Is it no problem such VIN terminal connection?
Also in the case of 4pcs of the device cascading, the customer wants to supply rower to the next TPS92661 VIN through the previous TPS92661 VIN terminal.
For example, the power supply output is connected to only VIN terminal (No.14) of the first device. The second device VIN terminal (No.14) is connected to only the other VIN terminal (No.23) of the first device.
Is the case of this, is thier any problem? Could you please give me your reply?
Your reply would be much appreciated.
Kazuya Nakai.
