Linux/LP5521SW-LINUX: can we make a driver for Linux 3.3?
Part Number: LP5521SW-LINUX
Other Parts Discussed in Thread: LP5521
Tool/software: Linux
Hi Team,
Customer is using our LP5521 for development.
And they are asking for driver specific for Linux 3.3.
The one we provided is for Linux 3.9, and it will show compile error under Linux 3.3, messages shown as below.
Please kindly help, thanks.
Andrew
nemo@nemo-VirtualBox:~/repoRoot/05/driver/lp5521$ make
make ARCH=arm -C /usr/src/arm-linux-3.3/linux-3.3-fa M=/home/nemo/repoRoot/05/driver/lp5521
make[1]: Entering directory '/usr/src/arm-linux-3.3/linux-3.3-fa'
  CC [M]  /home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.o
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c: In function ‘lp55xx_set_brightness’:
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:139: error: ‘struct lp55xx_led’ has no member named ‘brightness_work’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c: In function ‘lp55xx_init_device’:
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:375: error: ‘struct lp55xx_platform_data’ has no member named ‘setup_resources’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:376: error: ‘struct lp55xx_platform_data’ has no member named ‘setup_resources’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:383: error: ‘struct lp55xx_platform_data’ has no member named ‘enable’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:384: error: ‘struct lp55xx_platform_data’ has no member named ‘enable’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:386: error: ‘struct lp55xx_platform_data’ has no member named ‘enable’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c: In function ‘lp55xx_deinit_device’:
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:424: error: ‘struct lp55xx_platform_data’ has no member named ‘enable’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:425: error: ‘struct lp55xx_platform_data’ has no member named ‘enable’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:427: error: ‘struct lp55xx_platform_data’ has no member named ‘release_resources’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:428: error: ‘struct lp55xx_platform_data’ has no member named ‘release_resources’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c: In function ‘lp55xx_register_leds’:
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:442: error: ‘struct lp55xx_device_config’ has no member named ‘brightness_work_fn’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:459: error: ‘struct lp55xx_led’ has no member named ‘brightness_work’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:459: error: ‘struct lp55xx_device_config’ has no member named ‘brightness_work_fn’
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c: In function ‘lp55xx_unregister_leds’:
/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.c:485: error: ‘struct lp55xx_led’ has no member named ‘brightness_work’
scripts/Makefile.build:305: recipe for target '/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.o' failed
make[2]: *** [/home/nemo/repoRoot/05/driver/lp5521/leds-lp55xx-common.o] Error 1
Makefile:1365: recipe for target '_module_/home/nemo/repoRoot/05/driver/lp5521' failed
make[1]: *** [_module_/home/nemo/repoRoot/05/driver/lp5521] Error 2
make[1]: Leaving directory '/usr/src/arm-linux-3.3/linux-3.3-fa'
Makefile:16: recipe for target 'all' failed
make: *** [all] Error 2
