I'm using the LM3424 as buck-boost to drive 8 LED's at 1.5A. I had thermal issues causating current derating over time, I remade the design and their performance is a lot better.
Now the problem is that I'm getting a lot of ringing on the SW signal and input voltage supply, I'm attaching scope shots.
Input voltage supply:
SW node waveform:
And a shot with zoom on the peak.
How can I reduce this ringing? I was thinking about adding a common mode choke right on the input to resonate at that frequency, but also, I'm not sure if I need to adjust some passives related to the control loop compensation.
I'm worried that this ringing gonna be a trouble with EMC radiation when we send it to certificate.
I'm adding schematics for reference.
Thanks!
