TPS92513HV: TIDA-01096, can't find the sample code
Part Number: TPS92513HV
Other Parts Discussed in Thread: TIDA-01096, CC2650, TIDA-01095, CC2540
Hi Team,
TIDA-01096 didn't include the SW sample code, please suggest where to find it? thanks.
www.ti.com/.../TIDA-01096
  • Hello Yue,
    I will find out who is responsible for this design and forward them this. Thanks,
    Clint
    Have you looked under the CC2650?
    3.1 Hardware Connections
    Figure 8 shows the hardware interconnections and wireless connections required for the TIDA-01096 to
    work as expected. As mentioned earlier, the TIDA-01096 connects as a BoosterPack™ Plug-in Module
    upon the CC2650 LaunchPad. Along with the TIDA-01095 and CC2650, either a BLE dongle—the TI
    CC2540 USB dongle has been used in this design—or a Bluetooth enabled phone (with a BLE scanner
    application) is required to control the dimming setting of the LED.
  • Sorry for delay. I'm clear about the hardware connections and familiar about BLE part including stack. But I noticed the TID mentioned about below code. can you please let me where can I find this code? I'm promoting this total solution to my HA related customers. thanks.
    #if defined(LED_Dimmer_CC2650LP)
    #include "LED_Dimmer/Board.c"
    Navigate to <directory-name>\LED_Dimmer. Select all the .C files except Board.C
    I believe someone is working on that I will check again.
