On item 9.2.3 of LP8860-Q1 datasheet there is a suggestion to use SQW signal connected to nFET gate, in case of non availability of a power signal, to protect OUTx pins.
Please would you kindly confirm if the protection mechanism involved is the use of the breakdown voltage of nFET to limit OUTx pin voltage.
I'd like also to assure that SQW may not be used, as I need a very strict control of LEDs current.
Best wishes,
