• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » TPS61043 Vout ripple
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Captured to TPS61043 Vout ripple wiki page Recapture
This question is not answered
Dan Tooth
Posted by Dan Tooth
on Nov 26 2011 10:11 AM
Genius10885 points
Hi
What is responsible for the very different Vout ripple seen in Figures 13 & 14 of the d/s?
The operating conditions look similar in terms of LED current, pk SW voltage. The d/s doesn't have anything to say about "Burst Mode" as in Figure 14. (Figure 13 labelled PFM Mode I would say is also a sort of burst mode.) And yet one gives high Vout ripple of 1Vpkpk and the other mode gives about 50mV.
My customer has L=4u7 and Cot=1uF and gets high ripple. So he changes Cout to 10uF and it is much better. I assume that this hysteretic type converter is fine with 10uF for Cout.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Michael Day
    Posted by Michael Day
    on Nov 27 2011 13:01 PM
    Mastermind36070 points
    TPS61043 datasheet figure 13 and 14 most likely have different component values.  The switch on-times, output voltage, and input voltage appear to be identical, so the inductor values should be the same.  Figure 14 was probably tested with a larger output capacitor which would be consistent with lower output voltage ripple and the "burst mode" operation.  This is an LED driver, so the output voltage ripple is typically not the main concern in the design.  The preferred output capacitor is the small 1uF output capacitor because is produces the most cost effective design with acceptable output voltage ripple.  If you want lower output ripple, you can use larger capacitor values.
    The "burst mode" operation refers to the situation where a single TPS61042 or TPS61043 switch cycle does not increase the output voltage enough to get the FB pin above it's hysteresis point and requires two or more switch cycles to make this happen.  When the FB voltage drops below the nominal reference voltage, the IC starts a switch cycle.  If at the end of the switching cycle, the FB voltage is above the hysteresis value (typically 25mV-50mV above the nominal feedback voltage), the IC stops switching and waits for the FB voltage to drop below the reference voltage before starting again.  If the FB voltage doesn't go above the reference voltage plus the hysteresis, the TPS61042 immediately starts another switch cycle.
    If you require a lower output voltage ripple, you can operate with a larger output capacitor.  This will not damage the IC.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
