• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » Please let me know about TPS65150 Soft start.
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Satoshi
Posted by Satoshi
on Mar 09 2012 11:59 AM
Intellectual340 points
There is a question about the soft start of TPS65150.
(Please look at the 13th page of the data sheet. )
1.Is the clock cycles equal to switching frequency?
2.Does the start-up time of input voltage have restriction?
  ・Is it required 5ms or more?
  ・Do any problems occur at the time of less than 5ms?
3.Is the input voltage power supply of the characteristic data of data sheet figure 8 supplied?
I would appreciate your favor which will be saved if you can advise .
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Brigitte
    Posted by Brigitte
    on Mar 12 2012 08:27 AM
    Verified Answer
    Verified by Satoshi
    Genius14085 points
    Hello Satoshi,
    Here the answers to your questions:
    [Brigitte] The clock cycle is given by the oscillator frequency in the elecrical characteristics table.
    [Brigitte] The softstart starts when the input voltage is higher than UVLO. As long as the source is able to deliver the current, I do not see a problem.
    [Brigitte] What do you mean with this? You can see the input voltage as the top waveform.
    Brigitte
    startup TPS65150
    Report Abuse
    • Reply
  • Satoshi
    Posted by Satoshi
    on Mar 12 2012 21:58 PM
    Hello Brigitte ,
    Thank you for giving advice instantly.
    Moreover, I answer about the following inquiry.
    [Answer]
    I want to know the input voltage of power supply circuit in Fig.8.
    (For example, Is it the composition which is using the DC ragulated power supply? )
    Satoshi
    Report Abuse
    • Reply
  • Brigitte
    Posted by Brigitte
    on Mar 13 2012 03:01 AM
    Verified Answer
    Verified by Satoshi
    Genius14085 points
    Hello Satoshi,
    Still I am not sure, if I understand you correctly. When you have a look on Figure 23, there is a schematic for 5V supply, VIN connection in this schematic is the same as used for Figure 8.
    So the 5V is connected to a lab power supply and this lab power supply starts with the rate you can see in Figure 8.
    Brigitte
    startup TPS65150
    Report Abuse
    • Reply
  • Satoshi
    Posted by Satoshi
    on Mar 26 2012 05:22 AM
    Hello Brigitte,
    Thank you for the advice.
    Moreover, I received the question in the following addition about current limit.
    When is the first step of current Limit begins to move ?
      - After the Q1 switching start or The input voltage is higher than UVLO?
    I would appreciate your favor.
    Satoshi
    Report Abuse
    • Reply
  • Brigitte
    Posted by Brigitte
    on Mar 26 2012 07:29 AM
    Genius14085 points
    Hello Satoshi,
    The IC will start the softstart procedure when the voltage comes out of UVLO and the output voltage of the boost converter almost reached the input voltage. So the softstart starts when the boost converter starts to switch.
    Brigitte
    startup TPS65150
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
