• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » cable length between TLC 5940 chips
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question has suggested answer(s)
Mirko Nuncium
Posted by Mirko Nuncium
on Mar 20 2012 13:15 PM
Prodigy30 points
Hi, Is there a limitation of cable length between daisy chained TLC5940's? I am trying to connect 14 chips using ethernet cable of 6 meters distance and encountering problems.
TLC5940
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Perry
    Posted by John Perry
    on Mar 20 2012 13:21 PM
    Intellectual1660 points
    Mirko,
    What is the spacing along the cable?  In other words, are the drivers placed every 6m / 14 = 0.42m or is each driver 6m from the previous?  What are they mounted to.  In general, the TLC5940 is not optimized for really wide spacing between drivers in a cascaded configuration.  We have parts intended for this purpose, so you might look at TLC5970, TLC59711.
    John
    Report Abuse
    • Reply
  • Mirko Nuncium
    on Mar 20 2012 13:48 PM
    Prodigy30 points
    Hi John, thank you for the quick answer,
    They are daisy chained in between eachother with cables of various lengths, from 0.5 meters to 6 meters (the longest) So chain is in total about 14 meters long. I use Arduino mega as the main driver. ethernet cable for comunication between chips and additional cable for 12v power with shared ground,  Chips are driving RGB 12v power leds.
    I tested the chain of 5 chips with shorter cables ( about 05metrs) and they work very well, but once i connected 6 meters cable, problem appeared.
    Do you know what is the maximum length i could use? and is there a way to expand it? I should stick to 5940's since i already purchased them and printed the circuit boards for them .
    Report Abuse
    • Reply
  • Brigitte
    Posted by Brigitte
    on Mar 21 2012 04:13 AM
    Suggested Answer
    Genius14085 points
    Hello Mirko,
    When you say "problem occurred", what exactly happened? Are the parts in the daisy change work properly up to a certain point in the chain and the ones after the first failing unit are failing as well? If this is the case, I expect that there is a timing issue between SCLK and SIN. Please measure these signals on each part with reference to the parts GND and check if there is a timing issue.
    There are 2 possible issues you could have in this case:
    - The slopes of the SCLK signal are getting flatter and flatter, the longer the SCLK line. You might need a buffer somewhere in the row to get the slopes steep again.
    - There is a short delay between the signal available on SIN and the MSB available on SOUT. This could as well lead to timing issues between SIN changing and SCLK rising for long distances. If this is the case, most probable you need to delay the SCLK for the later parts somehow.
    Brigitte
    TLC5940 timing long distance
    Report Abuse
    • Reply
  • Mirko Nuncium
    on Mar 21 2012 09:17 AM
    Prodigy30 points
    Hi Brigitte, I have a flicker problem with long cable even when only one module is used, meening that SOUT-SIN connection is not in use.  In other case, with 3daisychained tlc's, when i connect 3rd tlc in the chain with cable that is 1meter long, my leds driven through 3rd chip are getting artifacts, they flicker when they should be off, and have low frequency when they are on, while first two chips are doing fine. Third chip also burns after some time i have a 1mf capacitor between gnd and vcc. You mentioned that i could make a buffer, how could i do that?
    Report Abuse
    • Reply
  • Brigitte
    Posted by Brigitte
    on Mar 22 2012 03:07 AM
    Genius14085 points
    Hello Mirko,
    Please check first if you have a GND problem on the module. Is the supply voltage changing through the long cable that could explain the flickering? So connect just one module through a long cable and measure the voltages on the module with respect to the GND pin of the IC. If all voltages are fine, go on with the next check below.
    When you observe the flicker issue and the supply voltage of the LEDs and the IC are stable, please measure the communication interface while writing to TLC5940. Through a long cable, the timings of the communication could be wrong writing strange content to the memory.
    Before making sure that all signals are correct and stable, it does not make sense to check if a buffer helps.
    Brigitte
    flicker TLC5940 timing long cable
    Report Abuse
    • Reply
  • Tilman Deuschel
    Posted by Tilman Deuschel
    on Jun 01 2012 04:28 AM
    Prodigy10 points
    Sounds like the frequencies of the ics are causing that problem. Set a 100uF cap between the power supply ground and 5V (yes, "shorten" the circuit) and on each ic an 0.1uF cap as close as possible to the ics power supply (gnd and vcc). I solved the same problem by doing so.
     Read this article for more information: http://www.eetimes.com/design/analog-design/4009954/Choosing-and-Using-Bypass-Capacitors-Part-1-of-3-
    Report Abuse
    • Reply
  • Rubin Chevak
    Posted by Rubin Chevak
    on May 18 2013 19:59 PM
    Prodigy10 points
    @John - Any way the LTC59711 can be daisy chain in lengths upto ~300-500ft for controlling multiple analog PWM servos?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
