• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » TLC5940 Shorting
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
TLC5940 Shorting
TLC5940 Shorting
This question is answered
Aaron Attar
Posted by Aaron Attar
on May 14 2012 05:09 AM
Intellectual275 points
I have 3 TLC5940's connected together and different channels on the drivers keep dieing.
I noticed that those channels who don't respond (to being told to turn off) are shorted to GND are are therefore always on!
I noticed that they tend to break when I turn on more the half the board in one request.
Any ideas?!
TLC5940
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Brigitte
    Posted by Brigitte
    on May 16 2012 15:44 PM
    Suggested Answer
    Genius14085 points
    Hello Aaron,
    Due to the fact that the outputs are shorted to GND, I expect that you are driving the output somehow outside the absolute maximum rating. Please check if the output pins are seeing voltages out of the range given in the absolute maximum rating. Please check the voltage with respect to the GND pin of the IC you are measuring on.
    The outputs could be damaged for example when due to GND shift the output swings negative.
    Please check as well if an increased decoupling capacitor per IC helps the issue.
    Brigitte
    Report Abuse
    • Reply
  • Aaron Attar
    on May 16 2012 19:30 PM
    When you say "driving the output somehow outside the absolute maximum rating" .... you mean more than the Vled of 17 volts?
    Also, when I am checking the voltage with respect to the GND pin of the IC I want to measure... I should be measuring the voltage differential between the IC GND and the Output Channel that's giving issues?
    thanks!
    Report Abuse
    • Reply
  • Brigitte
    Posted by Brigitte
    on May 18 2012 06:35 AM
    Verified Answer
    Verified by Brigitte
    Genius14085 points
    Hello Aaron,
    When I say outside of the absolute maximum rating, I mean either higher than the maximum or lower than the minimum value.
    You do not need to measure differential, but for an accurate measurement you need to put the oscilloscope probe close to the IC pin and not somewhere else on the board.
    Brigitte
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
