• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » recommendation for efficient led drver
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
or sam
Posted by or sam
on Aug 14 2012 06:54 AM
Intellectual780 points
Hi
I would like to get recommendation for most efficient driver for low voltages (3.3V) to controll 1 led using I2c,pwm,spi or any kind of digital communication, the max needed current is 200 mA but efficient is needed becuse it is working on batteries.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Vincenzo Pizzolante
    Posted by Vincenzo Pizzolante
    on Aug 17 2012 08:02 AM
    Genius9665 points
    so you need a buck led driver...
    the "closest" device to your needs seems to be the LM3405
    Vincenzo
    Report Abuse
    • Reply
  • or sam
    Posted by or sam
    on Aug 19 2012 05:37 AM
    hi
    this is not good for my application.
    I need controllable led driver I want to control the current because I measure the amount of light from the led. the PWM dimming you recommended is problematic because it is on and of and not controll the current.
    in addition I also need something with the same demand for 40mA.
    thanks
    Report Abuse
    • Reply
    on Aug 20 2012 09:15 AM
    Genius9665 points
    ok, in this case you can then use an LDO in current source configuration.
    something normally made with an LM337
    Vincenzo
    Report Abuse
    • Reply
  • or sam
    Posted by or sam
    on Aug 21 2012 01:55 AM
    Hi
    this in to good as well, please read the first post it should be digitally controlled.
    sorry for the mistake in the first post the current is 20mA not 200mA as was written...
    what about:
    TPS60250?
    Report Abuse
    • Reply
  • Sami Kotijarvi
    Posted by Sami Kotijarvi
    on Aug 21 2012 04:01 AM
    Intellectual770 points
    When I first read this post I thought you want a very simple driver that drives only one LED output with current output 0-200 mA or 0-40mA, but with the TPS60250 it seems that you could settle for 25mA/output (or 80mA with 4 level dimming) and the device could have more than one output?
    I browsed through and found TLC5970. Would that be suitable for you? The maximum current is controlled with external resistor (max curren capability is 150 mA/channel). There is a 7-bit dot correction in the device.
    Then there is devices like LP5521, which has three LED outputs with 25.5 mA maximum current. Device has 8-bit PWM and 8-bit current control.
    More complex device is LM8502 where there are 9 LED outputs and 2 flash LED outputs. LED output maximum current is adjusted with bit selection (3/6/12.5 or 25.5mA max) adn there is 8-bit current control with the selected maximum. Flash current is with 37.5 mA stepping from 37.5 to 600 mA and torch current is from 18.75 mA to 150 mA with 18.75 mA step.
    Sami
    Report Abuse
    • Reply
  • or sam
    Posted by or sam
    on Aug 22 2012 03:26 AM
    Hi Sami
    1. I can settle for 25mA (200 is a mistake I made). as for more then 1 output I prefer 1 output but if it doesnt exist I would not use all the ports.
    2. yes it seem to do the work although I need to build the protocol for SCKA and SCKB so I prefer to use more known protocols...
    3. this also seem to be good.
    why dont you recommend on the tps60250?
    thanks,
    Report Abuse
    • Reply
  • Sami Kotijarvi
    on Aug 22 2012 03:57 AM
    I am not saying that TPS60250 would not be a good fit to your application. I was just offering you other choices in case you want smaller pin number. Also I am more acquainted with LP5521 than TPS60250. So feel free to choose what ever suits the best your application.
    In our group we have one product for driving 1 LED output (LP5560), but it is driven directly from battery. This device has only 4 pins (VDD, LED, GND and CTRL). There is a single-wire interface and the LED current is adjustable (3-bit) from 2.5 mA to 20 mA with 2.5 mA step. This is in a micro SMD package. To let you know in case the package is a limitation in your application.
    Sami
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
