• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » Greyscale clocking of the TLC5941
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Adrian Grindon
Posted by Adrian Grindon
on Sep 25 2009 12:23 PM
Expert6500 points
I am using cascaded TLC5941s.
The data sheet is not very clear about when you clock the greyscale data into it. Can you clock in the new data during the pwm cycle, ie while GSCLK is running? Or do you have to do it during the blanking period after the 4096 GSCLK pulses?
I can't get it to work if clocking in during the pwm cycle, it only works if I do it during the blanking period. However this reduces the overall pwm frequency of the LEDs and creates an "off" time while I reload the greyscale data.
Should it work?
TLC5941
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Michael Day
    Posted by Michael Day
    on Oct 02 2009 13:18 PM
    Verified Answer
    Verified by Brigitte
    Mastermind36070 points
    While displaying Frame N (a PWM cycle), you can clock in Frame N+1 data.  After Frame N is complete, pull BLANK high and toggle XLAT from low to high and then high to low.  This will latch the new N+1 data into the internal registers.  TLC5946 datasheet, Figure 31 provides an example of this timing.  The figure shows the 192 bit dot correction data entry (16 channels * 6 bit dot correction * 2 ICs).  It then shows the 384 bit grayscale data entry (16 channels * 12 bit grayscale * 2 ICs).  After this frame is latched into the IC, the grayscale clock starts.  While the grayscale clock (GSCLK) is running, the next frame of 384 bit grayscale data is entered.  Note that this data can not be latched until after the grayscale completes it's 4096 steps and BLANK is pulled high.  The only "off" time you should have is when the BLANK signal is pulled high.
    You must be careful to ensure the TLC5941 setup and hold requirements are met.  If your signal drive strength is too low, the signal edges will be rounded due to the board capacitance on the data and clock lines.  There is no requirement to buffer the clock or any other signals.  However, depending on your specific drive strengths, board capacitances, clock speeds, timing between signals, you may need to buffer your signals to meet the TLC5941 timing requirements.  If you are at the limits of the setup and hold requirements and have rounded edges on your clock and data signals, you might be able to shift the timing between your signals to resolve the problem.  It may require a buffer.
    Report Abuse
    • Reply
  • YoYoFlex
    Posted by YoYoFlex
    on Nov 11 2009 16:46 PM
    Prodigy20 points
    You able to toggle XLAT from low to high and then high to low without pulling BLANK high.
    I'm using TLC5940, it has an external circuit, that refresh the grayscale counter, it connects to the BLANK and GSCLK pins and it's running continuously at 20MHz. The MCU connects to the XLAT, SCLK, SIN, SOUT etc... And the two circuit is completely independent.
    I don't try it on other devices than TLC5940, but the TLC5941 seems to has the same grayscale circuitry, that this can be works on it.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
