I have 2 led string with 6 30mA LEDs. Thats 12 leds.
Is it possible to connect 2x6 LEDS to 1 TPS61160/1? Will they be the same brightness? Do I need to use a resistor in series to balance it out.
I know that LEDs voltage varies from part to part(with same current). But will this be noticable when all the leds are the same and the temperature on all leds is the same?
Is there any other part that is best suited?
The goal is driving leds with brightness control and having the best efficiency.
