• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » LED Drivers/LCD Bias » LED Drivers/LCD Bias Forum » TLC5951 | A few questions
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Antennahead
Posted by Antennahead
on Dec 21 2009 12:05 PM
Expert3515 points
I have a couple of questions regarding the TLC5951’s Auto display repeat mode and the timing reset mode.
If I put a message up by setting XBLINK high after XLAT goes high then set Auto display=1, do I not have to change the state of XBLINK until I want to write a different message?  The GS counters don’t reset since XBLINK does not go low so I do not have to rewrite the GS data? Does Display timing reset mode only determine if GSLAT or XBLINK reset the GS counters?
 Thanks and best regards, Steve, TI-AFA Colorado
TLC5951 XBLINK GS GSLAT XLAT
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ChristianHoefling
    Posted by ChristianHoefling
    on Dec 22 2009 04:38 AM
    Verified Answer
    Verified by ChristianHoefling
    Expert6060 points
    Yes this is correct, you do not need to change toggle XBLINK signal to reste the graysclae counter. In auto repead mode the grayscale counter is reset automatically and the complete garyscale cycle is repeated until you disable the auto repead mode or pul XBLINK low to turn off the outputs
    Yes the grayscale counters reset automatically, in auto repeat mode you do not need to reset the grayscale counters wit XBLNK signal.
    Anyway you do not need to write new grayscale data since one grayscale cycle is repeated. In case you write new garyscale data it depends if the display reste timing is enabled or disabled.
    If display timing reset is disabled you should pull XBLNK high after a full gaysclae cycle before you latch new garysclae data in with GSLAT.
    If dispaly timing reset is enabled, you can connect XBLNK to VCC, and simple latch new gartsclae data with GSLAT.
    When display timing reset is enables the XBLNK can be connected to VCC (it is not needed). If display timing reset is enabled all outputs are forced off and the grayscale counters are restet to zero with rising edge of GSLAT. A new PWM gryascale cycle starts with the next rising edge of GSCKR/G/B
    TLC5951 Auto Repeat GS XLAT Display Timing Reset GSLAT XBLINK
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
