Linear Regulator Forum Ground Rules
Welcome to the Linear Regulator Forum.  In order to help us give you a high level support, please:
1) Make your login your first and last name.  This makes it easy to contact you outside the forum when necessary.
2) START the Subject line with the part number, FOLLOWED by a short description of what the post is about.  This helps others quickly find posts for the parts they are responsible for supporting and helps with future searches.
3) Please use tags for your posts.  Include the part number in question plus additional key words such as "ripple, failure, efficiency, overcurrent, etc." The tags improve future search functionality and will help others find the post if it is relevant to their problem.
4) If you are satisified with the answer, PLEASE mark the thread as "Answered."
