• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Linear Regulators » Linear Regulators - Forum » 1.2 V LDO
Share
Linear Regulators
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
1.2 V LDO
1.2 V LDO
This question is answered
Amit Kumar
Posted by Amit Kumar
on Aug 29 2011 07:20 AM
Prodigy70 points
Dear Sir,
Please suggest me a LDO with active low enable pin.
Vout=1.2
Iout=3A
Amit
power supply voltage regular LDO Linear regulator LDO's Vout voltage voltage regulator
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Michael Day
    Posted by Michael Day
    on Aug 29 2011 09:23 AM
    Mastermind36070 points
    The power supply selection tools will provide you with a list of LDOs that meet your power requirements.  You can then review the ICs in more detail to find one with an active low enable.  I don't think one exists.   One option is to invert your enable signal with a simple inverter IC, or by using a MOSFET.
    Report Abuse
    • Reply
  • Michael Day
    on Aug 29 2011 09:25 AM
    This is also a good question that you can work with your local distributor to answer.
    Report Abuse
    • Reply
  • Jeff F
    Posted by Jeff F
    on Aug 29 2011 10:53 AM
    Verified Answer
    Verified by Jeff F
    Mastermind22355 points
    The closest part that meets your needs would be the TPS75701/TPS75801.  However, the lowest output voltage these can provide is 1.22V not 1.20V.  So if you used our selection tool and entered 1.20V as the your desired output votlage, these IC's would not show up.  Also, their minimum input voltage is 2.8V so at full output current, this regulator would need an external heat sink and/or additional airflow to dissipate (2.8V-1.22V)*3A = 4.7W.
    If you have a 3.3V or 5V rail available to provide VBIAS, then I recommend either the TPS74401 or TPS74901.  You can provide the VIN power rail for either of these with a 1.5V or 1.8V rail and reduce the required power dissipation.  Both of these parts can be configured to provide 1.20V using external feedback resistors however, you will need an external, low-cost FET to invert your enable signal.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
