• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Linear Regulators » Linear Regulators - Forum » LP2989 Output is not 3.3
Share
Linear Regulators
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Stephen Doll
Posted by Stephen Doll
on Feb 01 2012 18:26 PM
Prodigy40 points
I'm a little stumped here.  I purchased several LP2989IMM-3.3 regulators.  I'm using the 10uF Input and 4.7uFOutput ceramic capacitance values and the actual circuit is right out of the data sheet.
I get a very stable 5.01 volts out of the part on the proto-boards.  It is supposed to be 3.3 volts.
I thought I had received the wrong part, but the top marking says LA2B, which seems to be correct for a 3.3 volt part.
It is the only regulator on the board, and should actually be tasked to provide 140mA at 3.3V from a 7.4V battery supply.
The only difference I can see between my circuit and the typical application circuit in the spec sheet is that I have a protection diode between input and output lines.
What am I missing?
LDO Linear regulator LDO's
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Donald Jones
    Posted by Donald Jones
    on Feb 01 2012 23:36 PM
    Expert6875 points
    I'm stumped as well. LP2989 is pretty straight forward. Stated top marking is correct for 3.3V version.
    Try going to just basic connections ... remove the protection diode, remove the pull-up resistor from the /ERROR pin, and remove the filter capacitor from the BYPASS pin, make sure the SENSE pin is connected directly to the OUTPUT pin, leave the Cin and Cout capacitors in place, and see what the difference might be.
    One thought ... It's possible to force Vout to a higher voltage by adding resistance between SENSE pin and OUTPUT pin, instead of direct a connection. I don't have the list needed values to get the 3.3V to 5.0V on hand at the moment, but he odds of getting so close to 5.00V at random would be very slim.
    Report Abuse
    • Reply
  • Stephen Doll
    on Feb 08 2012 08:58 AM
    Verified Answer
    Verified by Donald Jones
    Prodigy40 points
    Thanks Donald,
    I did all of that and the voltage output did not change, but it pointed me in the right direction.  I wired up a LP2989 just by itself with no pcb and the output was a stable 3.3.  At that point I knew it was something on the board.  I lifted the output and sense pin and the node on the pcb remained at 5V.  Aha moment, the problem is not the 2989 at all.
    Started to get the feeling that this was one of those awkward inept moments I sometimes have........Yep, it was......I eventually found a solder splash at the other end of the board tying the battery supply voltage through another component to my 3.3V bus.  So, if anyone out there runs into this, make sure you do not have another voltage impinged on your output line.
    Report Abuse
    • Reply
  • Donald Jones
    on Feb 08 2012 10:34 AM
    Expert6875 points
    Good to hear that you got it resolved. Thanks for the feedback.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
