• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Linear Regulators » Linear Regulators - Forum » TPS71750DSE - Overcurrent problem or...?
Share
Linear Regulators
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Stefano Infante
Posted by Stefano Infante
on Apr 18 2012 10:41 AM
Intellectual660 points
on a board I am using a TPS71750 (DSE type) in order to power: ADS1274 (75 mA max in high resolution mode), THS4524 (5.2 mA max), OPA2365 (10 mA max) and three accelerometers (10 mA max each). The total max current is about 120 mA. I have to add some little more current for a voltage divider which constitutes the reference voltage for the sensors, but that's less than 1 mA.
The problem is that TPS71750 does not seem to work as I would expect. With a 5.8 V input, the output is about 1.6 V. This appears to me as an overcurrent problem, but TPS71750 is stated to source up to 150 mA (and more, looking at the data sheet). Moreover, those listed above were maximum values, which I would only expect to find at extreme temperatures.
I double checked my schematics and found nothing should be wrong. What more can I check? Is there anything more I should be aware of?
And, should it really be an overcurrent problem, is there any 5 V LDO rated for 200 mA+ AND with the same DSE package (6-SON 1.5x1.5 mm)?
Thanks in advance,
Stefano Infante
ADS1274 overcurrent TPS71750
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Darwin Fernandez
    Posted by Darwin Fernandez
    on Apr 18 2012 13:40 PM
    Genius11750 points
    Hi Stefano,
    Can you attach a schematic of your application with the TPS717 so that we can look at it in detail?
    Does the LDO start up to the correct output voltage when the load is removed, if so, then yes, there may be a larger load at the output than expected. Unfortunately, we do not have a pin-pin device with a higher current rating for the TPS717. We do have some fixed 5V LDO with different packages like the TPS7350 (500mA), TPS76750, and TPS76850 (1A) that are fixed and have higher current. But there would be more options with an adjustable version.
    Darwin
    current limit output TPS717 load
    Report Abuse
    • Reply
  • Stefano Infante
    on Apr 19 2012 06:39 AM
    Hello Darwin,
    here you can find the schematics concerning TPS717. Please note that the third part is to be intended x3 (as there are three identical parts for the three axes X, Y, Z), and that on the second part the jumper is not mounted while the 2 resistors marked as "do not mount" are actually mounted, in order to let TPS717 supply the 2.5 V reference for the three sensors.
    From other tests, I found that the overall current drawn by the circuit at 6 V is 120 mA, but the circuit also has digital power supplies and other stuff. Moreover, if I try to shut down the ADC, the voltage on the TPS717 output goes down to 0.8 V...
    Thanks for your help,
    Stefano
    Report Abuse
    • Reply
  • Darwin Fernandez
    on Apr 19 2012 17:35 PM
    Genius11750 points
    Hi Stefano,
    Thanks for the schematic.
    From your description it seems that it may well be the load that is causing this. Have you checked to see if the output starts up correctly with the load removed?
    Your schematic seems okay. But here are some recommendations:
    What is resistance of the fuse? Or actually, what is the voltage right at IN? Be sure you are not at dropout. What are the voltage ratings of your input and output capacitors? 1uF (effective capacitance) is recommended. You may need to increase this. How far are your capacitors from the pins of the IC. Typically you want them as close as possible to the IC's pins.
    Darwin
    Report Abuse
    • Reply
  • Stefano Infante
    on Apr 20 2012 05:51 AM
    Hi Darwin,
    I made another test: I disabled the 5V output on the board and connected a 5V source directly on the TPS717 output; this way, I can measure the effective current drawn by the 5V line, and it is about 35 mA, so I don't think I have a load problem. I removed the load (by simply not powering the ADC lines), but nothing seems to change; on the contrary, the voltage on the output goes down to 0.8V. I did not try to physically disconnect the ADC from TPS717, as it would be a little more difficult.
    About the recommendations: the fuse does not seem to be the problem, as I can correctly see the 5.8 V line after the fuse (taken directly on TPS717); as TPS717 is stated to have a 0.3 V dropout, I am sure I am not in dropout. The input and output capacitors are AVX 0805YC105JAT (X7R, 1 uF, 16V), so I don't think they could be the problem. The capacitors are quite near the chip (I guess a few millimeters).
    Now I also have another problem: the ADC does not seem to work, even with this external 5V input. Maybe I have to check it all again. But I don't know whether the two problems can be connected or not...
    Thanks again,
    Stefano
    Report Abuse
    • Reply
  • Darwin Fernandez
    on Apr 20 2012 09:29 AM
    Genius11750 points
    Hi Stefano,
    The external components you chose are okay.
    From the description above, if the output is dropping even when using an external supply, it seems like the ADC (or some other load) is causing the power supply to current limit and drop the output voltage. Be sure that no abs max conditions are being violated for any of the components. Possibly a short somewhere under some condition or maybe the board layout. Regards,
    Darwin
    Report Abuse
    • Reply
  • Yao Zou
    Posted by Yao Zou
    on Apr 25 2012 03:44 AM
    Prodigy20 points
    Hi, Stefano
    I met the same problem. The symptom is very similar with yours. Output voltage is only about 0.8~1.0v when getting loads.
    I finally found the TPS71750 is put in reverse direction on the PCB board. You know this chip is very tiny... . After the direction problem is fixed, it works.
    I suggest you to check that.
    Zou Yao
    TPS717
    Report Abuse
    • Reply
  • Stefano Infante
    on Apr 26 2012 03:17 AM
    Darwin,
    maybe I was not so clear in explaining what I did... with the external supply, the ADC does not work correctly, but the power supply is not current limited and stands correctly at 5 V; so I have now two different problems: TPS71750 is not providing the correct voltage (but this has nothing to do with overcurrent, as the external power supply only draws a few tens milliamps), AND the ADC is not working.
    Now I have to solve both...
    Stefano
    Report Abuse
    • Reply
  • Stefano Infante
    on Apr 26 2012 03:28 AM
    Hi Yao,
    did you find the output voltage to be 1.3 V with no load? I will surely check the direction, but it apparently is ok. If you use the same package (DSE), can you please confirm the dot on the top of the chip is located on the pin #1, as usual? On the data sheet I did not find any information about this... it only says pin #1 is specified by a longer pin, but nothing is written about what can be found on its top...
    Stefano
    Report Abuse
    • Reply
  • Yao Zou
    Posted by Yao Zou
    on Apr 26 2012 04:36 AM
    Prodigy20 points
    Hi, Stefano
    I also use DSE package. With no load, the chip outputs 5.2v with 6.0v input, with load, it drops down to 0.8v.
    I cannot see the dot clearly, but only the "PD" mark on the chip. If yours is the same, the correct direction (from the top view) is as follows, the first pin is below the char 'P' :
    6   5  4
    ___ __
    |  PD   |
    1   2   3
    OUT GND NR/FB
    Hope it's useful to  you.
    Zou Yao
    Report Abuse
    • Reply
  • Stefano Infante
    on Apr 26 2012 05:34 AM
    Yao,
    this is very useful to me, as it allows to know for certain how the chip is mounted on my board. Unfortunately, it is mounted in the correct direction (with pin #1 on the chip corresponding to pin #1 on the PCB), so I have to look somewhere else. By the way, in my board the output voltage is 1.36 V when the load is disconnected (ADC in power down) and it goes down to 0.8 V when I try to switch on the ADC output.
    Thanks again.
    Stefano
    Report Abuse
    • Reply
  • Darwin Fernandez
    on Apr 26 2012 10:02 AM
    Genius11750 points
    In lab under the external components and operating conditions Vin=5.8V, and Iout=120mA, I have a 5V output. Possibly the ADC issue and LDO issue are related. It would be best to check the LDO in a separate circuit (with an external input power supply and resistive load) or somehow cut/disconnect the trace connecting the output of the LDO to all the loads to know for sure. If the IC is operating correctly, it must be the loads or the PCB layout.
    Darwin
    Report Abuse
    • Reply
  • Stefano Infante
    on Apr 27 2012 03:52 AM
    I think you're right: it must be something in the ADC circuit causing both problems. I have an ADC evaluation board: I will use it to check the board ADC circuit, and see what's wrong. At this point, I have little doubt about the TPS71750, it will probably work correctly if I disconnect all loads.
    After this check, I will write here again to get more advise from you :)
    Thanks again,
    Stefano
    Report Abuse
    • Reply
  • Stefano Infante
    on May 09 2012 07:38 AM
    Verified Answer
    Verified by Stefano Infante
    I solved the problem: it was my fault, on the board schematics I used the SC70 pinout for TPS71750, but on the PCB I used the WSON version, so the pins do not correspond to the PCB footprint.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
