• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Linear Regulators » Linear Regulators - Forum » TPS7A7300 Simulation Model
Share
Linear Regulators
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
This question is not answered
Mark Panzer
Posted by Mark Panzer
on Jul 17 2012 13:31 PM
Prodigy70 points
Sir/Madam,
I'm trying to use the TPS7A7300 simulation model in Cadence PSPICE 16.5 (with the AMS simulator option) and I'm running into a few issues. When setting the model to an output voltage other than the simulation default using the pin selection method it appears I cannot set the device below ~1.2V. Additionally, I attempted to apply a dynamic load (current step load) to the output of the supply and the output voltage changes dramatically (~200mV) for the duration of the step -- essentially mirrors the shape of the current instead of having a leading and trailing transient. Are you aware of any issues with this model?
Thank you,
Mark Panzer
Model PSPICE
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Britt Brooks - WEBENCH® Design Center
    Posted by Britt Brooks - WEBENCH® Design Center
    on Jul 17 2012 15:21 PM
    Expert7380 points
    Mark,
    I have just tested the model using the ground taps. If you remove them all, you get 0.5V. When adding each tap, the resulting voltage was increased by the proper amount. Can you provide your schematic or a .zip file of the PSpice directory you are using?
    I am not running PSpice 16.5, however. I am using version 16.2.
    The LDO model used is a very simple behavioral model that may not represent the transient changes in the load properly. It will change when the load changes, however, the resulting waveform may not be completely accurate. As with any model, this is one of the many trade-offs we made when choosing what kind of model to represent the LDO behavior.
    Britt
    Report Abuse
    • Reply
  • Mark Panzer
    on Jul 17 2012 15:32 PM
    Prodigy70 points
    Britt,
    Please see the attached .zip of the working directory. 7416.TPS7A7300_PSPICE_TRANS.zip
    The changes I've made to the base simulation are changing the input voltage to 1.5V, changing the taps to 1.0V, and adding a pulsing current load.
    My intention for the simulation was to get a feel for the dynamic characteristics of the converter with significant load capacitance at the output (not yet added). Given the information above that this is mainly a behavioral model, would you be able to provide information about the internal error amplifier GBW product / control loop compensation components to allow for modeling of the control system? I'm assuming it might not be worth any time investigating my issue running the model if it appears to not contain the frequency dependent characteristics I'm looking to simulate.
    Thank you,
    Mark
    Report Abuse
    • Reply
    on Jul 17 2012 15:46 PM
    Expert7380 points
    Mark,
    I do not have access to the information you would need for that kind of modeling. The best source would be the design team. You are correct in that the model would not contain this information in the detail you are needing.
    Britt
    Report Abuse
    • Reply
  • Bill Stokes
    Posted by Bill Stokes
    on Jul 17 2012 15:52 PM
    Expert8810 points
    Hi Mark,
    Mostly these new LDOs have multiple loops and defy this type modeling - yet I have asked for the information you have requested.  No promises, but maybe the system engineer can give us some general guidelines on what you ask.
    Report Abuse
    • Reply
  • Bill Stokes
    on Jul 17 2012 15:56 PM
    Expert8810 points
    Mark,
    How much load/output capacitance and esr do you need/want?
    Bill
    Report Abuse
    • Reply
  • Mark Panzer
    on Jul 17 2012 16:00 PM
    Prodigy70 points
    Thanks, this is all good info.
    Here's what I'm trying to validate through simulation:
    1. The input to this converter is from a high current 1.5V switching regulator with a large amount of ceramic capacitance on it's output (this converters input) in the neighborhood of 1000uF.
    2. This converter is powering sensitive high speed transceivers that require 1.0V with around a maximum voltage deviation of 10mV peak when going from idle to full load (say 100mA load to 2A).
    3. I would estimate I need in excess of 220uF of capacitance on the output of this converter, this is from extrapolating the waveforms provided in the datasheet -- I'm just not sure if I can say 10x the capacitance gets me to 10x lower disturbance on the output.
    Report Abuse
    • Reply
  • Mark Panzer
    on Jul 17 2012 17:03 PM
    Prodigy70 points
    Bill,
    I realized I didn't answer your question on ESR. The bulk ceramics I'm looking at have an ESR around 3 milli-ohms each, at the resonant frequency the ESR could be as low as 750 u-ohms + board effects, so I would say single digit m-ohms are possible. There will be significant decoupling of this supply up to reasonably high frequencies (total impedance under 100 m-ohms up to around 100 MHz).
    Mark
    Report Abuse
    • Reply
  • Bill Stokes
    on Jul 17 2012 18:04 PM
    Expert8810 points
    Hello Mark,
    The other day we used the TPS7A7300 (basically the same part) to step from 2mA-3Amps at 1V OUT using a feed forward capacitor of 2nF from VOUT to FB and Cout=100uF.  The transient peak (dip) was 48mV.  A 1% transient - particularly at 1Vout - is very tough.  (This was for a 1us/Amp step in load current)
    This will take some experimentation on your part - but my only other suggestion is to try the TPS74401, which is slightly faster with better phase margin.  Even here you will need a large amount of output capacitance, and a feed forward capacitor across the upper feedback resistor (to shunt the transient directly to the error amp)(1-2nF is usually good for this).
    You might be successful if your transient step is much slower than 1us/amp.
    Also - you should get an Evaluation Module (EVM) for each LDO from the TI website for experimentation.  This is really the only good way I have found to verify that this can be done.
    Good Luck
    Bill
    Report Abuse
    • Reply
  • Mark Panzer
    on Jul 20 2012 10:46 AM
    Prodigy70 points
    Bill,
    Thanks for the feedback, I'm going to go ahead and try to prove this out experimentally as per your suggestion. Thank you for the feedforward cap recommendation.
    Mark
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
