• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Linear Regulators » Linear Regulators - Forum » Not getting current at output.
Share
Linear Regulators
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
nikhil vv
Posted by nikhil vv
on Jul 31 2012 05:40 AM
Prodigy180 points
Dear Sir/ Madam,
I am Using LM1117 adj regulator for my project application.When i testing the circuit output I am getting voltage from 1.43 upto 4.93 Volts.
But the problem is when i came to check the current its showing '0'. The circuit connected as follows.
20V ,4.5A from SMPS to 1.33K Resistor to reduce to less than 15v.
Positive terminal to Pin no 3 of LM1117.
Ground to Pin 1.
from  pin 3 to 1 having 10uf tantalum capacitor.
pin 2 has 100e resistor and its connected to  10 pot. The other end of pot is grounded.
And Having one more capacitor of 10uF Tantalum on output pin no 2 to ground.
Checking the output across second capacitor capacitor.
My application need 2.5v ,250 mA .
Please help to get the required output.
Nikhil
LM1117 ADJ
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Donald Jones
    Posted by Donald Jones
    on Jul 31 2012 15:00 PM
    Verified Answer
    Verified by nikhil vv
    Expert7545 points
    See Figure 1 in the LM1117 data sheet for connections for the '-ADJ'  version. Note that the LM1117 GND/ADJ pin does not go to GND in the adjustable configuration
    You did not mention exact package type, but the pin#'s narrowed the possibilities. For your application, the connections should look like this ...
    Pin 1 = ADJ feedback pin
    Pin 2 & TAB = Vout pin
    Pin 3 = Vin pin
    The seemingly low values for R1 and R2 are correct and are to ensure that the minimum load current requirement is always met, and keeps voltage errors due to the Iadj current at a minimum. The TAB=Vout  is the same as Pin 2=Vout on the TO-220, TO-263 and SOT-223 packages, do not connect the TAB to GND.
    Report Abuse
    • Reply
  • nikhil vv
    Posted by nikhil vv
    on Aug 04 2012 04:17 AM
    Prodigy180 points
    Dear Sir,
    I think the problem is on the resistor it self which is using to reduce less than 15v.  because that emitting only 0.02A i think.. let me check and tell you what is happening ...
    I am agreeing my connection also have error.. Thank you for clearing the path..
    Nikhil
    Report Abuse
    • Reply
  • Donald Jones
    on Aug 05 2012 21:24 PM
    Verified Answer
    Expert7545 points
    Nikhil,
    My apologies for not including a suggestion for the series R to drop voltage from 20V to 15V at 250mA
    Vdrop = ( 20V -15V ) = 5V
    I = 250mA (for load) + 10mA for regulator bias = 260mA
           R = 5V / 260mA = 19.2 ohms
           W = 5V x 260mA = 1.3 Watts
    So, that's ~20 ohms, rated at 1.5W minimum
    Report Abuse
    • Reply
  • nikhil vv
    Posted by nikhil vv
    on Aug 06 2012 08:01 AM
    Prodigy180 points
    Sir,
    Thank you very much...
    but one doubt....
    Does it compulsory to connect the Tab pin to pin no 2 as per the diagram (Package TO-220)??
    Report Abuse
    • Reply
  • Ron Michallick
    Posted by Ron Michallick
    on Aug 06 2012 08:17 AM
    Verified Answer
    Mastermind30930 points
    Nikhil,
    Pin 2 and the tab are connected internally on the device.
    It is not necessary to connect to both.
    Ronald Michallick
    Linear Applications
    TI assumes no liability for applications assistance or customer product design. Customer is fully responsible for all design decisions and engineering with regard to its products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning Customer's design. If Customer desires engineering services, the Customer should rely on its retained employees and consultants and/or procure engineering services from a licensed professional engineer (LPE).
    Report Abuse
    • Reply
  • nikhil vv
    Posted by nikhil vv
    on Aug 07 2012 03:04 AM
    Verified Answer
    Prodigy180 points
    Sir,
    That query for confirmation. because in previous post it is connected to output.
    Thank you for the support.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
