hi,
I'd like to use a TPS7A7300 linear regulator with a digital pot. Can I use the FB pin to have a vout of 0.9v to 1.05v? Can I adjust Vout up to 5v with a digital pot?
I'll be disconnecting the sense pin and the configuration resistors if I use the digital pot, I assume this is the right way of doing it.
Is there any other consideration of using a digital pot on TPS7A7300?
rdgs
Ferdie
