Would you suggest component values/rating succesfully applied before in combination with TPS54122? Someone out there must have used this device many times. What components may not be needed?
Thanks and Regards,
Rodney
Thanks and Regards,
Rodney
Hi Rodney,
The component values and if the components are needed depends greatly on your application. Please see the Design Procedure for TPS54122 for how to select the proper components for your application: http://www.ti.com/lit/an/slva602/slva602.pdf
Very Respectfully,
Ryan
