Hi I'm trying to design my own bench power supply and I'm considering using am LM317 as a starting point.
I've looked at datasheet number: SNVS774O MAY 2004 REVISED JANUARY 2014.
In figure 42 the is a circuit for a constant voltage/constant current but the value of the variable resistor (R8) for voltage adjustment isn't specified.
What value it should be?
Ideally, I'd like to build a tracking regulator (+/- 30v) with independent constant current settings for each rail (or at least an indication when either rail exceeds a set point).
So is there a modification for figure 42 where the voltage is set with just a single “R8” (to allow tracking), but there would still be a “R2” for each rail?
Thanks, Trevor
