Please let me know the operation of TPS78001 with prebiased condition and concern. I'm assuming the 2.5V prebias will be applied to Vout via 10kohm after power up. I understand that the output voltage can not be regulated correctly and the Vout will be higher than normal voltage.
- Do you think this will be cause of damage or unstable operation?
- Do you think this will be cause of false operation of active pull-down circuit?
Your comment will be appreciated.
Sonoki / Japan Disty
