Hi all,
In NR pin of TPS799 (fixed voltage) which need a 0.01uF bypass capacitor, in analog applications that need to have Analog and Digital ground separated, should I connect this capacitor to Analog or Digital ground?
Hi all,
Thanks for your answer. About connection of Analog plane to Common ground plane I've found that it's highly adviced to use a single connection point. It's ever better, as someone say or as adviced in some application notes, to connect Analog plane through a FB to Common plane. In case of lackage of information about specifics of this FB or in general case about separating Digital and Analog ground, how do you advice to choose this FB specifics? Or there's a common value used in specific applications? (like: Digital between 10-50Mhz or 100-500Mhz ecc.)
