Part Number: TPS7A4533
I have a customer looking to use the TPS7A4533 as they need low noise and high PSRR. However, they are trying to reduce the dissipation in the LDO by lowering the input voltage. I know PSRR decreases as you get closer to the LDO's drop out voltage. As far as I can see, the PSRR curve in the data sheet doesn't specify a the voltage drop across the LDO. What were the test conditions for the ripple rejection curve (Figure 24) in the data sheet (Vin, Vout, Iout)? And do we have curves for lower drop out voltages?
Please let me know.
Thanks & regards, John Garrett, TI AFA
