Hello All, for the part TPS7A3501, the datasheet specifies a block diagram, can anyone help to understand how is this working. Is the opamp indicated in the block diagram a simple opamp or is there any level shifter kind of structure also involved.
if i understand correctly for a given resistor value between NR and ground the dropout will remain constant irrespective of the load current?
