What are the layout guidelines for the TPS75801? Is there any example with a multilayer PCB with power and ground plane?
I've read the recommendation from the datasheet but there aren't any layout guidelines. Input and output capacitors should be placed as close to the device pins as possible.
Is it recommended that the board to be designed with separate ground planes for IN and OUT?
